[Gdal-dev] java swig create options
Norman Barker nbarker at ittvis.com
Thu Jul 20 12:41:54 EDT 2006
When I use createCopy from Java and pass in a vector of create options,
where each option in the vector is expressed as a string name=value, it
has no effect on the output image.
However using gdal_translate .. -CO "NAME=VALUE" and I get the desired
result. Is this a bug, or is there a slightly different way of passing
in create options from Java?
Thanks,
Norman
