[Gdal-dev] How do i create a Mercator Projection from a BSB file?
Christopher Barker
Chris.Barker at noaa.gov
Fri Jul 21 15:54:05 EDT 2006
Hi all,
I'm trying to figure out how to map from pixel coords to lat-long (and
back again) from a noaa raster nautical chart (BSB). gdalinfo gives this
data that's relevant:
Driver: BSB/Maptech BSB Nautical Charts
Size is 10877, 9391
Coordinate System is `'
GCP Projection = GEOGCS["WGS 84",
DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG",7030]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG",6326]],PRIMEM["Greenwich",0,AUTHORITY["EPSG",8901]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG",9108]],AXIS["Lat",NORTH],AXIS["Long",EAST],AUTHORITY["EPSG",4326]]
GCP[ 0]: Id=GCP_1, Info=
(248,8558) -> (-89.55,28.7669,0)
GCP[ 1]: Id=GCP_2, Info=
(248,483) -> (-89.55,29.3502,0)
< and a bunch more GCPs >
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 9391.0)
Upper Right (10877.0, 0.0)
Lower Right (10877.0, 9391.0)
Center ( 5438.5, 4695.5)
As far as I can tell, there is only Geographic Coordinate System info in
the WKT. Here it is expanded for easier reading:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AXIS["Lat",NORTH],
AXIS["Long",EAST],
There doesn't seem to be any projection info anywhere. Except maybe
where it says:
What does the number after "degree" mean?
However, there is more data in the top of the *.kap file, that the
driver doesn't seem to extract:
PTC/Maptech,KAPLib V5.0.0.4,12/20/2005
BSB/NA=MISSISSIPPI RIVER DELTA,NU=57,RA=10877,9391,DU=254
KNP/SC=80000,GD=NAD83,PR=MERCATOR,PP=29.133,PI=10.000,SP=Louisiana
South,40000
SK=0.0000000,TA=90.0000000,UN=FEET,SD=MEAN LOWER LOW
WATER,DX=8.00,DY=8.00
KNQ/EC=RF,GD=NARC,VC=UNKNOWN,SC=MLLW,PC=MC,P1=UNKNOWN,P2=29.133
P3=NOT_APPLICABLE,P4=NOT_APPLICABLE,GC=KK,RM=POLYNOMIAL
CED/SE=72,RE=1,ED=10/01/2004
NTM/NE=72.63,ND=12/17/2005,BF=OFF,BD=10/01/2004
Here's what I recognise and think is relevant from that:
Scale:80000
Projection: PR=MERCATOR
Reference Latitude: 29.133
Now I've dug into the osr.py, and found that SetMercator requires:
SetMercator( self, clat, clong, scale, fe, fn )
Which I think means:
# which I think means;
# clat --- Latitude of the projection origin.
# clong --- Longitude of the projection origin (central meridian?)
# scale --- Scale factor applies to the projection origin.
# fe --- False easting.
# fn --- False northing."""
So where to I get that data from the above?
I think I got clat from there: 29.133
clong, I have no idea.
Scale is given as 80000, and that's the scale of the paper cahrt, but I
don't know how to convert that to pixel coords.
Is there a False easting or False northing for this chart?
Any help would be appreciated.
Also, it seems that the BSB driver could be extracting more info than it
does -- is there a reason for that? or does someone just need to write
the code? If the later, than if someone can tell me what fields in
GDALDataset should be filled with what from the *.kap[ file, I could
probably submit a patch.
By the way, is there an easier way to do this? It seems a common need to
create an OGRSpatialReference from the data in a GDALDataset. Is there
an existing method to do that?
thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
