[Gdal-dev] GML to shapefile
Bart van den Eijnden (OSGIS) bartvde at xs4all.nl
Wed Jul 26 05:18:31 EDT 2006
Hi Mateusz,
oops, my fault :-) I had forgotten to do so.
I have now opened a bug for the ms: attribute name in dbf issue:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1250
Thanks in advance foor looking into this.
Best regards,
Bart
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> a while ago I reported a problem with Mapserver GML to shapefile
>> conversion using ogr2ogr, the dbf column names are ms:XXXX.
>> Has this been fixed (ie the namespace removed from the attribute name)?
>> Should I open up a bug report?
> Hi Bart,
> Obviously, I've forgot about this problem, I'm sorry.
> So, please, file a bug with sample GML files attached then it won't be
> forgotten.
> AFAIR from our e-mails exchange you were going to file a bug with
> sample data files:
> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008944.html
> and here is your last response I got about this problem:
>> Hi Mateusz,
>> I have the file at work, will open up a bug on Monday and attach it to
>> it.
>> Best regards,
>> Bart
>>>> Hi Frank, Mateusz,
>>>> I am not saying it is invalid GML, I am saying the values are wrong.
>>>> XMIN and YMIN in the Mapserver GML are:
>>>> 192519.015625
>>>> 320687.375000
>>>> But in OGR's output they are both 0.
>>>> I will file some bugs on Monday.
>>> Hi,
>>> Strange.
>>> I have a sample of GML 2.0 file with
>>> <gml:boundedBy>
>>> <gml:Box>
>>> <gml:coordinates>
>>> 278653.100,187444.800 279095.300,187898.250
>>> </gml:coordinates>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> and after I run
>>> ogr2ogr -f "GML" test.gml MySampleGML.gml
>>> the output is changed but correct:
>>> <gml:boundedBy>
>>> <gml:Box>
>>> <gml:coord><gml:X>278653.1</gml:X><gml:Y>187444.8</gml:Y></gml:coord>
>>> <gml:coord><gml:X>279095.3</gml:X><gml:Y>187898.25</gml:Y></gml:coord>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> I'd need to test using your GML file. Is it possible send me one?
>>> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
