[Gdal-dev] building gdal with kakadu
trale at centrum.cz trale at centrum.cz
Wed Jul 26 17:30:59 EDT 2006
Hi Frank,
I figure that out somehow. I have kakadu 4_2_1_00336C with gdal13 working now. There is other issue that worried me more. I have this output on gdalwarp.- it used to work. Any idea or workaround ? here is the dump:
C:\ ...... >gdalwarp -t_srs WGS84 mosaic.tif geomosiac.tif
ERROR 1: Too many points (441 out of 441). failed to transform, unable to compute output bounds
mosaic.tif is in UTM and it is ok, based on globalmapper
______________________________________________________________
> Od: warmerdam at pobox.com
> Komu: trale at centrum.cz
> CC: gdal-dev at lists.maptools.org
> Datum: 26.07.2006 23:20
> Předmět: Re: [Gdal-dev] building gdal with kakadu
>trale at centrum.cz wrote:
 >> Hi list,
 >> I am having troubles with building gdal with kakadu support - under
 >> Windows. I have edited the nmake.opt file and set the KAKDIR to the folder
 >> of my kakadu installation. The build brakes on the kakadu partr since it
 >> can not find some files. Any idea or help ?
 >Nick,
 >It would be helpful to know what versions of GDAL and Kakadu you are using.
 >Did you already build all of Kakadu?
 >I would suggest quoting the errors here for better support.
 >Best regards,
 >I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
 >light and sound - activate the windows | http://pobox.com/~warmerdam
 >and watch the world go round - Rush    | President OSGF, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060726/341b90d8/attachment.html
