[Gdal-dev] gdal java bindings
Christopher Condit
condit at sdsc.edu
Fri Jul 28 06:52:05 EDT 2006
Hi Daniele-
No, I'm not sure that it does. But here's the thing that bugs me: when I
run my Java code it concludes that
Min=-128
Max = 127
However, when I run gdalinfo on the file, I get the following
information:
Driver: JPEG/JPEG JFIF
Size is 2592, 1296
Band 1 Block=2592x1 Type=Byte, ColorInterp=Red
Computed Min/Max=0.000,235.000
Band 2 Block=2592x1 Type=Byte, ColorInterp=Green
Computed Min/Max=0.000,228.000
Band 3 Block=2592x1 Type=Byte, ColorInterp=Blue
Computed Min/Max=0.000,238.000
So I thought I might be reading the ByteBuffer incorrectly.
Thanks,
Chris
From: Daniele Romagnoli [mailto:dany.geotools at gmail.com]
Sent: Friday, July 28, 2006 1:36 AM
To: Christopher Condit
Subject: Re: [Gdal-dev] gdal java bindings
Hi Cris.
Are you sure that the rasterBand of your sample file contains the Offset
and Scale values?
They are optional properties of a RasterBand.
I have used your code with my HDF format samples and it works fine.
Maybe your sample has no information about this.
regards, Daniele
On 7/28/06, Christopher Condit <condit at sdsc.edu > wrote:
Does anyone have experience with the GDAL Java bindings? I'm trying to
use them for raster access and can't seem to get the raw data.
The key problem seems to me that band.GetOffset, GetScale, and
GetNoDataValue are failing. They all return void in the Double[]. Am I
calling them wrong? getXSize/getYsize works fine.
Here's the function:
void dump()
Band band = image.GetRasterBand(1);
int x = band.getXSize();
int y = band.getYSize();
ByteBuffer data = ByteBuffer.allocateDirect(x * y);
band.ReadRaster_Direct(0, 0, x, y, x, y,
band.getDataType(), data);
Double[] offset = new Double[1], scale = new Double[1],
nodata = new Double[1];
band.GetOffset(offset);
band.GetScale(scale);
band.GetNoDataValue(nodata);
double min = 1000;
double max = -1000;
while ( data.hasRemaining())
double val = (data.get() * scale[0]) +
offset[0];
if (val < min)
min = val;
if (val > max)
max = val;
System.out.println(min + " " + max);
Thanks,
Chris
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060728/1a2a9d89/attachment.html
