hi all, is there a possibility to convert with ogr lines to polygones, for example like ogr2ogr -f "ESRI Shapefile" -nlt POLYGON c:\home\dat_poly.shp c:\home\dat_line.shp or does somebody know another open source solution for this task. thanks for your help and greetings from munich christian
