[Gdal-dev] RE: Gdal-dev Digest, Vol 25, Issue 1
Shaun Kolomeitz
shaun.kolomeitz at epa.qld.gov.au
Thu Jun 1 22:08:39 EDT 2006
Martin,
Many thanks for the suggestion however I am using gcc-3.4.2 (plus gmake 3.8) on Solaris10.
LDFLAGS=-lstdc++
CFLAGS="-D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64"
LD_LIBRARY_PATH=/usr/sfw/lib:/usr/local/lib:/opt/csw/lib:/usr/lib
PATH=/usr/sfw/bin:/usr/local/bin:/opt/csw/bin:/usr/bin:/usr/sbin
export PATH LD_LIBRARY_PATH LDFLAGS CFLAGS
./configure --with-gnu-ld --prefix=/usr/local/bin --with-local=/usr/local \
--with-pg=/usr/local/pgsql/bin/pg_config --with-mysql=/usr/bin/mysql_config \
--with-jasper=/usr/local/include/jasper --with-ecw=/usr/local \
--with-mrsid=/usr/local/GeoExpressSDK --with-static-proj4=/usr/local/share/proj --with-geos=/usr/local/bin/geos-config \
--with-python
Are you able to compile in ECW ? ECW Compiles successfully (with the examples running fine), but GDAL has a cow when compiling with ECW.
Regards,
Shaun
> Date: Thu, 1 Jun 2006 09:57:37 +0000 (UTC)
> From: Martin Spott <Martin.Spott at mgras.net>
> Subject: Re: [Gdal-dev] GNU Compile of GDAL on Solaris
> To: gdal-dev at lists.maptools.org
> Message-ID: <e5mdmh$14u0$1 at osprey.mgras.de>
> Gregory Yetman wrote:
> > I did some digging, apparently the math.h library has been replaced
> > with a .so file on Solaris. There is a math.h file in:
> > /opt/sfw/lib/gcc-lib/sparc-sun-solaris2.9/2.95.3/include/ [...]
> I can't tell you any specifics regarding your GCC version. Maybe you'd
> want to try GCC-3.4.2 from Sunfreeware which I used to compile
> GDAL-1.3.1 on Solaris8,
> Martin.
___________________________
Disclaimer
This e-mail, including attachments if any, has originated from a Queensland government agency and may contain information that is confidential, or covered by legal professional privilege, and is intended for the named recipient(s) only. If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer system network.
Any form of disclosure, modification, distribution and/or publication of this e-mail, including attachments is prohibited. Unless otherwise stated, this e-mail, including attachments represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all possible viruses have been detected and cleaned. Any use of this e-mail could harm your computer system.
