[Gdal-dev] Re: [mdb-dev] Invalid soname
Mateusz Loskot
mateusz at loskot.net
Mon Jun 5 12:35:21 EDT 2006
Ups! Sorry, I put wrong e-mail address.
Please, ignore this post.
Mateusz
Mateusz Loskot wrote:
> Jeff Smith wrote:
>>--- Mateusz Loskot <mateusz at loskot.net> wrote:
>>>As you can see, MDB Tools libraries have invalid soname.
>>>Accordint to odbcinst.ini definition of MDB driver, I had to create symlink:
>>>$ ln -s /usr/local/lib/libmdbodbc.0.0.0 /usr/local/lib/libmdbodbc.so.0
>>>Is this known issue or I did something wrong?
>>Yes, this is a known issue with 0.6pre1, which shipped with a bad ltmain.sh.
>>Option 1: go to source directory, run 'libtoolize -f -c', then rerun
>>configure/make/make install. Option 2: use mdbtools from CVS.
> Jeff,
> Thank you for your explanation.
> It's clear.
> Cheers
Mateusz Loskot
http://mateusz.loskot.net
