[Gdal-dev] gdalwarp Transparency Question
Reinaldo Escada Chohfi
rec at geodesign.com.br
Mon Jun 5 13:13:11 EDT 2006
Hello,
I'm runing gdalwarp (FWTools 1.0.0a7) to mosaic geotiff images because the
images are large and I run into memory problems with gdal_merge.
I get some strange results in several mosaics in the overlapping areas
between images. I use -srcnodata 0 to have gdalwarp do the transparency in
these overlapping areas.
My question is, if am using -scrnodata 0, will the transparency be made
when all 3 pixel values are 0, 0, 0 (RGB) or whenever any of the bands has
a pixel value equal to 0? It looks like I get a transparency only in the
Blue, sometimes only in the Red or Green bands and the image has blue, red
or green spots. Do I have to use -scrnodata value "0 0 0" in order to get
transparency only when RGB are equal to 0, 0, 0?
Thanks in advance for the help.
Reinaldo
