[Gdal-dev] tiff to jp2ecw
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 6 07:55:42 EDT 2006
Mark Overmeer wrote:
> This works well, thank you.
> The next step is to add/change color-interpretation and band-names.
Mark,
Setting band names is not supported by most format drivers, including
the jpeg2000 drivers.
To set the band color interpretation I would suggest using the
-co PHOTOMETRIC=RGB flag to gdal_merge.py. This is a TIFF specific
flag, but once the TIFF file is set appropriately; hopefully the JPEG2000
will pick it up too.
The only other user-accessable mechanism for setting band color interpretation
(other than writing python/etc scripts) would be to create a VRT file - and
XML header of sorts - and adjust the band color interpretation in this.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
