DIY: Reprojection...Re: [Gdal-dev] raster image preprocessing
problem.
Robert Rose
robert.w.rose at gmail.com
Tue Jun 6 12:00:46 EDT 2006
On Jun 6, 2006, at 6:42 AM, Charles Wivell wrote:
> Hi all;
> There's been a lot of mail about reprojecting from one map
> projection to another. Writing a ditty (scientific term for quick
> program) to reproject an image from one map projection to another
> is pretty straight forward, once you have a projection library.
> The projection library I use is called GCTP (General Cartographic
> Transformation package) it is free from the USGS.
> ftp://edcftp.cr.usgs.gov/pub/software/gctpc/
> I'll pseudo code the process below (the steps are the same no
> matter what language you use).
> 1) Read in the image into a memory buffer (input space)
> 2) Get the current map projection information (Projection, datum,
> Upper left corner projection parameters, size of pixel in X and Y)
> 3) Frame your output space
> - Calculate the output space upper left and lower right values
> - Lat, Lon, projection x/y, output space pixel size
> 4) Create a memory buffer for the output space
> 5) For each pixel in the output space
> 6) Find the projection x/y using the pixel size and offset of the
> pixel from the upper left corner
> 7) Convert output space projection x/y to lat, lon using GCTP
> (inverse projection)
> 8) Convert lat, lon to input space projection x/y using forward
> projection routine in GCTP
> 9) Convert projection x/y into line, sample (row, column)
> 10) Resample DN values in input space near the calculated input
> space line, sample
> 11) Place resampled DN value into the output space at current pixel
> location (line, sample)
> 12) Get next output pixel location (back to step 5)
> 13) Write the output space buffer to a file
> I'm use to using the terms line, sample since my background is from
> satellite imagery (thats was usually how they collected data a line
> scanner). It is just the same as row, column or y,x (line is in the
> y direction and sample is in the x direction)
> These are also the basic steps to warp an image from one space to
> another, just that steps 7 and 8 are replaced with a mathematical
> relationship, usually a polynomial of some kind. Or if I'm taking
> raw satellite imagery or photography and projecting it into a map
> projection then steps 7 and 8 are replaced with a platform/sensor/
> earth mathematical model.
> In step 10 you can use Nearest Neighbor (just round to the nearest
> pixel location) or for a little better looking final image use
> bilinear resampling.
> Oops... I just gave away all my secrets of being a Geospatial
> programmer.... ;-)
Hi Chuck, I sent out that email last week about re-projecting a
Plate Carree image of the Earth into Mercator... (I still haven't
gotten a sufficient answer btw)..
Sure, I could use the process you describe above to re-project the
image myself programmatically, but isn't the process you describe
above exactly what gdalwarp is for? Or do I have gdalwarp completely
mistaken? If so, that would explain why I haven't gotten it to do
what I want! :-)
Actually I have had success using gdalwarp to convert UTM
orthoimagery to Mercator, but that's obviously a much smaller area
than the Earth. Does gdalwarp have any limitations when you give it
an image that's suppose to cover the entire Earth? Maybe that's why
I can't get this to work.
-robert
