[Gdal-dev] ERMapper .ers ?
Brent Fraser
bfraser at geoanalytic.com
Tue Jun 6 15:49:32 EDT 2006
Tanya,
Yes, the .ers header file can reference a BIL file (that's the default).
And no, GDAL does not directly support the reading or writing of .ers files.
An .ers file can be simple or quite complicated, depending on your data
organization. Here's an example of a simple one:
DatasetHeader Begin
Version = "5.5"
LastUpdated = Tue May 23 16:01:15 GMT 2006
DataSetType = ERStorage
DataType = Raster
ByteOrder = LSBFirst
CoordinateSpace Begin
Datum = "WGS84"
Projection = "NUTM39"
CoordinateType = EN
Rotation = 0:0:0.0
CoordinateSpace End
RasterInfo Begin
CellType = Unsigned8BitInteger
CellInfo Begin
Xdimension = 49.9887396648
Ydimension = 49.9887396648
CellInfo End
NrOfLines = 449
NrOfCellsPerLine = 690
RegistrationCoord Begin
Eastings = 333482.7994339
Northings = 1788902.13974
RegistrationCoord End
NrOfBands = 3
BandId Begin
Value = "Red"
BandId End
BandId Begin
Value = "Green"
BandId End
BandId Begin
Value = "Blue"
BandId End
RasterInfo End
DatasetHeader End
As Frank points out, you could use gdal_translate to create a BIL/HDR file,
then use some sort of scripting to create a .ers file for each BIL from the
information in the .hdr files.
And there are a few details:
1. Typically in ERMapper's world the BIL file has the same name as the .ers
file, but no .bil extension
2. The coordinate system descriptors ("WGS84", "NUTM39" ) are ERMapper's
own, so you'll need to find out which ones to use for your data.
3. If you care about pixel registration, note that the registration
coordinates in a HDR file are the center of the top left pixel, while the
default in an ERS file is the top left corner of the top left pixel (1/2 a
pixel different in x and y). You can change this default in an ERS file by
adding:
RegistrationCellX = 0.5
RegistrationCellY = 0.5
after
Brent Fraser
GeoAnalytic Inc
Calgary, Alberta, Canada
----- Original Message -----
To: <gdal-dev at lists.maptools.org>
Sent: Tuesday, June 06, 2006 12:18 PM
Subject: [Gdal-dev] ERMapper .ers ?
> I'm curious about being able to convert a large bunch of files to ER
> Mapper .ers format. From what I've been told, .ers is basically a .bil
> format raster with a custom header. Not sure how accurate this
> description is, but I'm curious if gdal can create it...
> we're looking at a project where we will have to convert a few large
> series of rasters into .ers format. The source files would include
> TIFFs, TIFFs w/ world files, ArcInfo grids, and/or DEMs. I was hoping
> gdal might be a potential aid in this big task.
> can someone enlighten me as to gdal's capabilities regarding .ers ?
> thanks
> Tanya
> From: "Frank Warmerdam" <warmerdam at pobox.com>
> To: <gdal-dev at remotesensing.org>
> Sent: Thursday, April 29, 2004 12:46 PM
> Subject: Re: [Gdal-dev] ERMapper .ers ?
> > Ben Discoe wrote:
> > > I've been asked about the ERMapper .ers format... could GDAL
read/write
> it?
> > > It seems to be an open format, in that ERMapper generally encourages
> people
> > > to use their format. It is a raster format, i think?
> > Ben,
> > From a few samples I have seen I gather the .ers file is basically an
> ascii
> > header describing an external raster file which can be in any number of
> formats.
> > I presume there is some raw raster format for files generated within
> ERMapper.
> > I think that in some cases the .ers file is also an algorithm
description
> of
> > how to generate a raster from other files.
> > However, I'm not really very sure of any of this.
> > If folks want to scare up some examples datasets (not too huge I hope) I
> > could look at implementing some degree of support.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial Programmer for Rent
> http://lists.maptools.org/pipermail/gdal-dev/2004-April/002593.html
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
