[Gdal-dev] gdalwarp Transparency Question
Tue Jun 6 19:41:09 EDT 2006
Reinaldo Escada Chohfi wrote:
> Matt,
> I've been successfully using the attached command lines in .bat files to
> crop and mosaic a large number of tiles.  Frank suggested to use
> gdalwarp because my input images are large (approx. 2 GB each) and
> gdal_merge loads entire images in memory and I was running into
> problems. You have to use gdal_merge first to create the image and them
> use gdalwarp to mosaic.  In my case the src and dst srs are the same.
> I also use gdal_translate because I load the tiles into another program
> that wants tiffs as INTERLEAVE=PIXEL.
Reinaldo,
I would add that gdalwarp should now support many input files, like
gdal_merge, and that creation options can be used directly with gdalwarp.
So, in theory your case could be expressed as:
gdalwarp -te 569600 10064800 578300 10057600 C:\Subsets\input\*.tif CD-043.tif
          -co INTERLEAVE=PIXEL
The many files in gdalwarp support was new for GDAL 1.3.2 in an effort
to de-emphasize gdal_merge.py.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
