[Gdal-dev] VRT to turn multiple points into a polyline
Tamas Szekeres
szekerest at gmail.com
Wed Jun 7 18:22:06 EDT 2006
I would suggest to create a LINESTRING WKT inside the query a read that
layer as with WKT geometry field.
Best Regards,
Tamas
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Daniel Morissette
Sent: Wednesday, June 07, 2006 10:44 PM
To: gdal-dev
Subject: [Gdal-dev] VRT to turn multiple points into a polyline
Let's say I have a flat database table with an X and a Y column, it is
easy to create a OGR-VRT data source to return the records as points.
Is there a way using the VRT driver to return a set of records with X,Y
columns as a single LineString instead of multiple points?
The reason why I'm asking is that I have an Oracle database with X, Y,
and TIMESTAMP columns, and I would like to use a SQL query in a VRT to
select multiple points over a period of time and return them as a track
(a LineString) instead of individual points for use in MapServer.
Does anyone know of a way to do that?
Daniel
Daniel Morissette
http://www.mapgears.com/
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.8.3/358 - Release Date: 2006.06.07.
No virus found in this outgoing message.
