[Gdal-dev] ogrinfo and oracle spatial
Mateusz Loskot
mateusz at loskot.net
Fri Jun 9 05:16:49 EDT 2006
Daniel Goetz wrote:
> I am new here. And I have a problem. I want to show geodata lying in
> an oracle spatial database via mapserver and I want to do this by
> using the OGR interface. My previous attempts to do so failed the
> mapserver telling me: "msOracleSpatialLayerOpen(): OracleSpatial
> error. OracleSpatial is not supported "
Daniel,
Sorry, I can't help you with MapServer stuff.
Please, ask on the MS lists.
> I downloaded FWTools and launched the setfw.bat. for testing purpose
> I launched the command "ogrinfo c:\ms4w\apache\htdocs\test" where I
> have some Shapefiles lying. ogrinfo told me that there are two
> shapefiles what is the truth.
FYI, note that OGR in FWTools may vary from OGR build in MS4W package in
what drivers are built-in and what are excluded.
To see drivers built into FWTools you installed, run:
ogrinfo --formats
> but now I don't know the command to test my database. I tried the
> following command: "ogrinfo oci:ggs_brwk2004_umn/umn at gds1prod". But
> ogrinfo told me that it was unable to open the datasource.
> Can anybody help me, please? Might it be that I have installed the
> oracle client on the "wrong" drive?
Have you checked this webpage:
http://www.gdal.org/ogr/drv_oci.html
There are all OCI options described in details.
You can also find there usage examples.
Generally, the OCI data source definition should follow this format:
OCI:userid/password at database_instance:table,table
List of tables is optional, but if present, note there should be no
spaces between colon, commas and table names.
So, in your example, try to run:
ogrinfo OCI:ggs_brwk2004_umn/umn at gds1prod
where:
ggs_brwk2004_umn - userid
umn - password
gds1prod - database instance
If this command will fail, please give all ogrinfo output with error
message.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
