[Gdal-dev] ogrinfo and oracle spatial
Daniel Goetz
madprof at gmx.ch
Mon Jun 12 06:51:16 EDT 2006
Thank you Howard and Mateusz for your help!!!
Now running ogrinfo it lists for one thing the OCI-support and for another it shows the tables in the oracle database that contain geometric data. That's really great. but I had to modify the command for ogrinfo: I wrote:" ogrinfo "OCI:username/password at host:port/sevice_name" instead of "OCI:username/password at service_name". Anyway, it works.
But now another problem occures concerning the mapserver: I "installed" the Oracle 10g instant client, set the windows environment variable PATH and did the .dll swapping like Howard and the readme file in the ms4w-package told me to do. Everything went fine until I want to test maping oracle spatial data via mapserver. the mapserver gave back the following: "mapserv(): Web application error. No template provided." I checked my .map-file for that but there I found a link to the template-file in the WEB-Object.
WEB
TEMPLATE "test_template.html"
END
After that I tested other test-projects that contain only shapefiles or rasterdata that had worked before the mentioned .dll swapping on my computer. but always the same error message was given out:
Has anybody an idea why this happens? What am I doing wrong?
Here is my mapfile:
MAP
NAME "Oracle"
EXTENT 426666.49 466058.21 448321.44 490754.58
SIZE 1400 1800
SHAPEPATH "/ms4w/Apache/htdocs/raster/daten"
IMAGETYPE PNG
IMAGECOLOR 255 255 255
UNITS METERS
STATUS ON
CONFIG "GDAL_DRIVER_PATH" "C:/ms4w/gdalplugins"
WEB
IMAGEPATH "c:\ms4w\Apache\htdocs\raster\tmp\"
IMAGEURL "/raster/tmp/"
END
LAYER
CONNECTIONTYPE OGR
CONNECTION "OCI:gds_brwk2004_umn/umn at geo0xs01:1523/gds1prod.geo.stadt.nuernberg.de"
DATA "RWG_TBS"
NAME "RWG_TBS"
TYPE POLYGON
STATUS ON
CLASS
NAME "Flaeche"
STYLE
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
END
END
END
Under "CONNECTION" in the LAYER-OBJECT I use the same phrase as in ogrinfo. the one including the host- and the port-data instead of the command shown in the mapserver-reference-guide "Vector Data Access" on http://mapserver.gis.umn.edu/docs/reference/vector_data , because I do not know where mapserver shall get these info (host and port) otherwise (but I also tested the version told in the reference-guide). As mentioned in the mail before, the database itself lies on a server in the intranet. Can anybody explain that to me? Thank you so much.
the linked tempalte is very simple:
<html>
<head>
<title>Erstes Beispiel zum UMN Mapserver</title>
</head>
<body>
Mapserver-Version auslesen:<br><br>[version]<br><br><br>
Karte einbetten:<br><br>
<img src="[img]"><br>
</body>
</html>
and to start the whole process I write the following command-line in my browser:
http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/raster/test_os_ogr.map&layers=all&
OK. That's it. I really don't know what exactly the problem might be. And I don't know how mapserver shall get access to the geodata in the oracle database without giving the host-address and the port-number. Would be very nice if somebody could help me. Thank you so much.
> Datum: Fri, 9 Jun 2006 08:18:52 -0500
> Betreff: Re: [Gdal-dev] ogrinfo and oracle spatial
> The latest MS4W is built with support for Oracle OGR support. You
> need to have the 10g client libraries installed on your path
> somewhere, and use the OGR_DRIVER_PATH/GDAL_DRIVER_PATH environment
> variables to activate it. See the readme file in MS4W for more
> information.
> In addition, the latest MS4W comes with Oracle MapServer support as
> well. See the readme file for more information on that as well.
> Using it involves a some dll swapping, but it isn't too bad.
> Howard
> At 12:51 PM +0200 6/9/06, Mateusz Loskot wrote:
> >Daniel Goetz wrote:
> >> Thank you Mateusz for your help.
> >> Unfortunatelly the command: "ogrinfo
> OCI:gds_brwk2004_umn/umn at gds1prod"
> >> brought back the following (this tiem I used the ogrinfo
> >> integrated in ms4w:
> >> FAILURE:
> >> Unable to open datasource 'OCI:gds_brwk2004_umn/umn at gds1prod' with
> >>the following drivers.
> >> -> ESRI Shapefile
> >> ->MapInfo File
> >> ->UK .NTF
> >> ->SDTS
> >> ->TIGER
> >> ->S57
> >> ->DGN
> >> ->VRT
> >> ->AVCBin
> >> ->REC
> >> ->Memory
> >> ->CSV
> >> ->GML
> >> ->ODBC
> >> ->PGeo
> >> ->PostgreSQL
> >> ->MySQL
> >>As you can see, list of supported drivers of your OGR does not include
> >OCI for Oracle Spatial.
> >This is the problem.
> >>> Subsequent I watched out fo the supported formats by commanding:
> >> "ogrinfo --formats"
> >> the result was:
> >> Loaded OGR Format Drivers:
> >> ->"ESRI Shapefiel"
> >> ->"MapInfo File"
> >> ->"UK .NTF"
> >> ->"SDTS"
> >> ->"S57"
> >> ->"DGN"
> >> ->"VRT"
> >> ->"AVCBin"
> >> ->"REC"
> >> ->"Memory"
> >> ->"CSV"
> >> ->"GML"
> >> ->"ODBC"
> >> ->"PGeo"
> >> ->"PostgreSQL"
> >> ->"MySQL"
> >>Yes, this is the same list as above you got with the error message.
> >>> Can you please tell me whether the needed driver for oracle
> >> spatial is supported in my OGR. Can you tell me what I further
> >> sould do.
> >>AFAIK,
> >you have to build GDAL yourself with OCI driver included in the OGR.
> >I'm writing 'AFAIK', because I don't know if there is any FWTools or
> >MS4W or any other package that provides OGR built with OCI support.
> >I assume you're using Windows, you can turn on OCI support by
> >editing nmake.opt file.
> >Find OCI word and you will see appropriate options/paths to enable this
> >driver (look for "Add ORACLE support" section).
> >On Unix, you can use --with-oci option for ./configure script.
> >BTW, I've never used OCI myself, so I'm giving you some suggestions I
> >base on my knowledge, but not experience.
> >Cheers
> >Mateusz Loskot
> >http://mateusz.loskot.net
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/gdal-dev
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
