[Gdal-dev] memory leak in MapInfo layer
Mateusz Loskot
mateusz at loskot.net
Tue Jun 13 15:56:11 EDT 2006
Richard Matsunaga wrote:
> I believe I am experiencing a memory leak in MapInfo tab layers using
> the C API (called by C# code).
Is this your own C# binding?
Could you provide a piece of code?
> I am writing points to a MapInfo tab file. If I don't add the point
> object to the OgrFeature, there is no leak. As soon as I add the
> point (or any geometry), the memory leak occurs.
How are you adding the geometry to feature?
There is a different semanting between SetGeometry and
SetGeometryDirectly regarding ownership of passed geometry.
BTW, how are you detecting memory leaks?
> If I choose a Shapefile datasource, there is no leak.
Hmm, so I'd suspect MapInfo driver is leaking but I'd need to know more
details about how are you using it.
> Could there be something I am doing wrong that is leading to this
> problem with MapInfo files?
Sure there could be a problem with using OGR incorrectly what can lead
to memory leaks.
> Another test that I did to confirm was to use 'OGR_F_SetGeometry'
> instead of 'OGR_F_SetGeometryDirectly' (and destroy the original
> geometry myself) and the same leak occurs.
Good test. So, something other place is leaking.
Please, provide us with more details about:
- C# bindings you are using
- piece of code you are creating/destroying geometries
Cheers
Mateusz Loskot
http://mateusz.loskot.net
