[Gdal-dev] Setting PROJ4 path programatically
Craig Miller
craig.miller at spatialminds.com
Wed Jun 14 17:33:34 EDT 2006
In digging through the archives, I found a post that briefly describes how
to set the path where PROJ4 looks for its data files (E.g. proj4/nad). The
message mentions two functions:
pj_set_finder(...);
CPLSetConfigOption("GDAL_DATA", ...);
If I'm only using OGRSpatialReference directly and not calling into proj4
directly is the CPLSetConfigOption sufficient or do I need to call
pj_set_finder(...) as well.
Will these calls affect any other applications that are running on the same
machine that are also using PROJ4?
Thanks,
Craig
