[Gdal-dev] Compile GDAL with VS2005 (BuildKit Source Code)
Zhonghai Wang
zhonghaiw at gmail.com
Thu Jun 15 08:49:15 EDT 2006
Hi guys,
compile GDAL is not a easy task, and till now I finally finished it, but
without the following components:
ECW, DWG/DXF, XERCES, MRSID, GEOS, POSTGIS, and MYSQL.
acutally I need the XERCES and GEOS components, but I can not get them work,
but I will try it again withe this two component, and hopefully can get some
help from you guys.
so I step now to the libraries needed by MapServer.
zhonghai
with all your help I've finished compiling the needed libraries by GDAL, and
On 6/15/06, Didrik Pinte <dpinte at itae.be> wrote:
> Le jeudi 15 juin 2006 à 09:36 +0200, Zhonghai Wang a écrit :
> > Hi Dirik,
> > you mean that I do not need to compile all the needed libraries from
> > the very begining?
> > the problem is now I want to compile GDAL and MapServer with VS2005,
> > but the needed Libraries by GDAL and MapServer were pre-compiled with
> > VS2003, as Howard said.
> > I'd like more details about the compilation.
> > thank you very much.
> > zhonghai
> What i'm saying is that you can be able to compile gdal and mapserver
> with using the libraries provided by the buildkit with the MSVC toolkit.
> So it won't be a VS2005 compilation but a VS2003 with the toolkit.
> Didrik
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060615/632e3ef5/attachment.html
