[Gdal-dev] IPCC raster format
Ivan Lucena
ILucena at clarku.edu
Fri Jun 16 11:08:54 EDT 2006
Hi there,
I would rather been watching the World Cup, but I have to get this data
in a usable format and there is no better place to get it than from
GDAL's experts.
The "Intergovernmental Panel on Climate Change" (IPCC) offers data on
the web in a format described by this Fortran source code: (The file
extension is just a generic ".dat")
http://ipcc-ddc.cru.uea.ac.uk/obs/observed_fileformat.html
> more cpre0130.dat
grd_sz xmin ymin xmax ymax n_cols n_rows
n_months
0.50 0.25 -89.75 359.75 89.75 720 360
12
-9999-9999-9999-9999-9999-9999-9999-9999-9999 52 88 103 91 65
45 27 32 ...
-9999-9999-9999-9999-9999 11 20 22 25 27 26 27 28 31
29 28 30 ...
It's not hard to analyze the pattern on the data or the code, so I
figured that:
- It's an ASCII format;
- There are two lines of reader (easy to read)
- Each cell is 5 characters wide;
- The no-data is "-9999";
- There is no separator between cells (what makes my task difficult);
- It's a multi-band raster dataset with 12 bands; (720x360x12 cells)
- I am not sure if positive values can go beyond 9999 (that reminds me
COBOL)
I am heading in the direction of writing a Python+GDAL script to do the
task, but I am stuck in how to separate the cells. The Fortran code is
doing it in just one command as you can see in the code. I am thing that
maybe by using the NumPY stuff embedded in GDAL I could do the same.
Any Idea? Any experience with this data format?
Thanks in advance,
Ivan
This is a Python command line interaction with the data:
>>> import gdal
>>> f = open('C:/Data/IPCC/cpre0130.dat', 'r');
>>> f.readline()
' grd_sz xmin ymin xmax ymax n_cols n_rows
n_months\n'
>>> f.readline()
' 0.50 0.25 -89.75 359.75 89.75 720 360
12\n'
>>> f.readline()
'-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-
9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-99
99-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999
program rd_ascii
! f90 program to read in an integer ascii grid with
! variable dimensions into a global grid (720x360x12)
parameter :: n_cols=720
parameter :: n_rows=360
integer, dimension (n_cols,n_rows,12) :: grid
character(len=72) :: infl
character(len=20) :: fmt
call getarg(1,infl)
if(infl.eq.' ')then
write(*,*) 'Enter ascii grid file name'
read(*,'(a72)')infl
end if
open(1,file=infl,status='old')
read(1,*)
read(1,*)xmin,ymin,xmax,ymax,ncols,nrows,nmonths,missing
grid=missing
fmt='( i5)'
write(fmt(2:4),'(i3)')n_cols
do im=1,nmonths
do lat=1,n_rows
read(1,fmt)(grid(lon,lat,im),lon=1,n_cols)
enddo
enddo
end program rd_ascii
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060616/f1956b56/attachment.html
