[Gdal-dev] Tool to convert shapefile from [-180, 180] to [0, 360] range
Martin Daly Martin.Daly at cadcorp.com
Mon Jun 19 07:39:11 EDT 2006
> I also have an extension to WKT for setting this.  I believe you add
> an entry like EXTENSION["CENTER_LONG",180] as a child of the
> GEOGCS node.
> I would have mentioned this whole issue here sooner, except
> that I just
> know that Martin Daly will now rightly jump all over me for corrupting
> the standard WKT format.  I must say, I now regret not having
> advocated
> on behalf of a vendor specific extension mechanism in the past. :-)
As predicted...
Can you handle any of this with a (standard) FITTED_CS instead of a
(non-standard) EXTENSION?
Martin
