[Gdal-dev] Re: Problem with GDALWARP - very fast to solve
Manuel Massing
m.massing at warped-space.de
Tue Jun 20 07:22:40 EDT 2006
Hello Jan,
> > www.esw.rwth-aachen.de/n56e010.bil
> it would be helpful if you could also provide the associated
> .hdr and .prj files.
in fact, the problem seems to be your target projection definition. The
srtm tile you specify resides in utm zone 32 (not 11), so you should try
gdalwarp -s_srs "+proj=latlong +datum=WGS84" \
-t_srs "+proj=utm +zone=32 +datum=WGS84" \
n56e010.bil test.tif
with the attached .hdr file. Works for me.
bye,
Manuel
Type: image/x-hdr
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060620/96a5b325/n56e010.bin
