[Gdal-dev] How to set a ColorTable from scratch?
Joaquim Luis
jluis at ualg.pt
Thu Jun 22 15:13:05 EDT 2006
Frank Warmerdam wrote:
> Joaquim Luis wrote:
>> Hi,
>> I finally learned how to use the Create() method. However, I didn't
>> find out how to create a new colortable.
>> There is the GDALSetRasterColorTable(GDALRasterBandH,
>> GDALColorTableH) but how do we fill the
>> GDALColorTableH?
> Joaquim ,
> The following code from gdal/alg/gdalmediancut.cpp shows adding
> a bunch of entries to a color table.
> for (i = 0, ptr = usedboxes; ptr != NULL; ++i, ptr = ptr->next)
> GDALColorEntry sEntry;
> sEntry.c1 = (GByte) (((ptr->rmin + ptr->rmax) << COLOR_SHIFT)
> / 2);
> sEntry.c2 = (GByte) (((ptr->gmin + ptr->gmax) << COLOR_SHIFT)
> / 2);
> sEntry.c3 = (GByte) (((ptr->bmin + ptr->bmax) << COLOR_SHIFT)
> / 2);
> GDALSetColorEntry( hColorTable, i, &sEntry );
Frank,
I had already came across similar code and I wanted to try it, though
expecting a crash as effectively
I just had.
The point (that is what I think) is who initializes hColorTable? I mean
how do we allocate memory to it?
Currently I just have
GDALColorTableH hColorTable;
for (i = 0; i < nColors; i++) {
sEntry.c1 = (short)(ptr_d[i] * 255);
sEntry.c2 = (short)(ptr_d[i+nColors] * 255);
sEntry.c3 = (short)(ptr_d[i+2*nColors] * 255);
sEntry.c4 = (short)255;
but it crashes at the first call to
Joaquim Luis
