[Gdal-dev] jp2kak on OSX
Dave Robertson dave at cs.otago.ac.nz
Sun Jun 25 19:32:45 EDT 2006
Frank,
Thanks for the advice.
./configure --without-python --without-ecw --without-libtool --with-
kakadu=< my absolute path to kakadu 5.1 >
Compiling gdal using the above configuration now returns a different
set of undefined symbols, but still appears to be using libtool
somewhere in the process.
ld: Undefined symbols:
__ZN11kdu_tiffdir12write_headerEP21kdu_compressed_targetx
__ZN11kdu_tiffdir4initEb
__ZN11kdu_tiffdir5closeEv
__ZN11kdu_tiffdir7opendirEP21kdu_compressed_source
__ZN11kdu_tiffdir8copy_tagERS_j
__ZN11kdu_tiffdir8open_tagEj
__ZN11kdu_tiffdir8read_tagEjiPd
__ZN11kdu_tiffdir8read_tagEjiPj
__ZN11kdu_tiffdir8read_tagEjiPt
__ZN11kdu_tiffdir8writedirEP21kdu_compressed_targetx
__ZN11kdu_tiffdir9write_tagEjiPd
__ZN11kdu_tiffdir9write_tagEjiPt
__ZN11kdu_tiffdir10create_tagEj
__ZN11kdu_tiffdir13get_dirlengthEv
__ZN11kdu_tiffdir9write_tagEjiPj
__ZN12jpx_metanode12get_existingERP14jp2_family_src
__ZN12jpx_metanode14get_descendantEi
__ZN12jpx_metanode8get_uuidEPh
__ZN16jpx_meta_manager11access_rootEv
/usr/bin/libtool: internal link edit command failed
make[1]: *** [/Volumes/FW28G/FW55G/projects/Searcher/gdal-kdu/
gdal-1.3.2/libgdal.dylib] Error 1
make: *** [check-lib] Error 2
Any suggestions?
Regards,
Dave Robertson.
> Dave Robertson wrote:
>> Hi,
>> I'm trying to compile GDAL 1.3.2 with Kakadu v5.1 on OSX but make
>> fails
>> with a lot of undefined symbols reported by libtool.
>> Looking back through the list and gdal changelogs, the latest
>> version of
>> kakadu mentioned is 4.0.2 in GDAL 1.1.9
>>>  JP2KAK Driver: Can be used with Kakadu 4.0.2 now.
>> Are later versions of kakadu supported, or to do I have to revert to
>> Kakadu 4.0.2 ?
> Dave,
> I believe I have always used --without-libtool when building in Kakadu
> support on unix systems.  The problem is that we explicitly pull in a
> bunch of object files from Kakadu directly, rather than as a library
> (because that is the only way Kakadu seems to offer them), and this
> seriously confuses the libtool build which seems to expect to control
> all object files "its way".
> I'm pretty sure I have tried at least Kakadu 5.0 on Linux, so I
> don't *forsee* a problem with 5.1 o MacOS X.  Hmm, in fact I'm pretty
> sure I tried Kakadu 5.0 or 5.1 on MacOS X a couple weeks ago without
> any significant problem (using --without-libtool).
> Best regards,
> Hi,
> fails with a lot of undefined symbols reported by libtool.
> Looking back through the list and gdal changelogs, the latest version
> of kakadu mentioned is 4.0.2 in GDAL 1.1.9
> Kakadu 4.0.2 ?
> Thanks,
> Dave Robertson
> __ZN10jp2_colour4initE16jp2_colour_space
> __ZN10jp2_source11read_headerEv
> __ZN10jp2_source14access_paletteEv
> __ZN10jp2_source15access_channelsEv
> __ZN10jp2_target12write_headerEv
> __ZN10jp2_target13access_colourEv
> __ZN10jp2_target14access_paletteEv
> __ZN10jp2_target15access_channelsEv
> __ZN10jp2_target15open_codestreamEb
> __ZN10jp2_target17access_dimensionsEv
> __ZN10jp2_target4openEP14jp2_family_tgt
> __ZN10jp2_targetD1Ev
> __ZN11jp2_palette12get_num_lutsEv
> __ZN11jp2_palette15get_num_entriesEv
> __ZN11jp2_palette4initEii
> __ZN11jp2_palette7get_lutEiPf
> __ZN11jp2_palette7set_lutEiPiib
> __ZN12jp2_channels15get_num_coloursEv
> __ZN12jp2_channels18get_colour_mappingEiRiS0_S0_
> __ZN12jp2_channels18set_colour_mappingEiiii
> __ZN12jp2_channels19get_opacity_mappingEiRiS0_S0_
> __ZN12jp2_channels19get_premult_mappingEiRiS0_S0_
> __ZN12jp2_channels19set_opacity_mappingEiiii
> __ZN12jp2_channels4initEi
> __ZN12kdu_roi_rectC1E14kdu_codestream8kdu_dims
> __ZN13jp2_input_boxC2Ev
> __ZN14jp2_dimensions4initEP10siz_paramsb
> __ZN14jp2_family_src4openEP21kdu_compressed_source
> __ZN14jp2_family_src4openEPKcb
> __ZN14jp2_family_src5closeEv
> __ZN14jp2_family_tgt4openEPKc
> __ZN14jp2_family_tgt5closeEv
> __ZN14jp2_output_box5closeEv
> __ZTV10jp2_source
> __ZTV10jp2_target
> make[1]: *** [libgdal.la] Error 1
