[Gdal-dev] jp2kak on OSX
Dave Robertson dave at cs.otago.ac.nz
Mon Jun 26 18:25:38 EDT 2006
Ben,
Thanks for that information. The build completes successfully now.
Perhaps a note to this effect could be included in the jp2kak
documentation?
Cheers
Dave Robertson.
> In Kakadu 5.1 there are two (new?) shared objcet files that are not
> explicitly mentioned in the GNUMakefile in frmts/jp2kak.  These files
> are:
> <kdu_dir>/apps/make/jpx.o
> <kdu_dir>/apps/make/kdu_tiff.o
> If those file are added to the GNUMakefile you will proabaly be
> able to
> build correctly.  I did not check the change into CVS because I'm
> concerned that doing so would break gdal builds for old versions of
> kakadu.
