[Gdal-dev] JP2KAK
Mark Overmeer
mark at overmeer.net
Wed Jun 28 08:10:26 EDT 2006
using FWTools 1.0.0a7 linux precompiled binaries
GDAL 1.3.1.0, FWTools 1.0.0a7, released 2005/11/10
I start gdal_translate with one tif which contains three gdal_merge'd
tiff bands:
gdal_translate -of JP2ECW my.tif my.jp2
output:
Input file size is 4980, 4200
0...10...20...30...40...50...60...70...80...90...100 - done.
Warning 1: Kakadu Warning:
Profile violation detected (code-stream is technically illegal).
Profile-0 code-streams must have nominally square code-block dimensions,
measuring 32x32 or 64x64. You should set "Sprofile" to 1 or 2.
two things:
1) why is Kakadu warning me? I select JP2ECW
2) how can I resolve the warning
Thanks in advance,
MarkOv
Mark Overmeer MSc MARKOV Solutions
Mark at Overmeer.net solutions at overmeer.net
http://Mark.Overmeer.net http://solutions.overmeer.net
