[Gdal-dev] Re: [GDAL Tasks] Autotest of PostgreSQL provider
Mateusz Loskot
mateusz at loskot.net
Fri Jun 30 08:58:22 EDT 2006
Hi Frank,
Here is small info regarding two extra tasks about ogr_pg.py.
Mateusz Loskot wrote:
> Two extra tasks:
> Check why two test cases fail:
> mloskot:~/dev/gdal/_cvs/autotest/ogr$ ./ogr_pg.py
> TEST: ogr_pg_1 ... success
> TEST: ogr_pg_2 ... success
> TEST: ogr_pg_3 ... success
> TEST: ogr_pg_4 ... success
> TEST: ogr_pg_5 ... success
> TEST: ogr_pg_6 ... success
> TEST: ogr_pg_7 ... fail
> field eas_id feature 0 did not match expected value 158, got 168.
My version of autotest database did not include PostGIS.
After I imported lwpostgis.sql file and plpgsql support,
the test case works - SetSpatialFilter does the job well.
> TEST: ogr_pg_8 ... success
> TEST: ogr_pg_9 ... success
> TEST: ogr_pg_10 ... success
> TEST: ogr_pg_11 ... success
> TEST: ogr_pg_12 ... fail
> expected geometry but got NULL.
Again, lack of PostGIS.
When no PostGIS is available GeometryToHex returns incompatible output.
After I changed it to GeometryToBYTA, geometries imported to non-PostGIS
database of PostgreSQL have valid values.
But, because PG test requires PostGIS, I reverted to GeometryToHex which
works well when PostGIS is available.
I added CPLDebug message to inform user that no PostGIS is available.
All ogr_pg.py tests succeed.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
