[Gdal-dev] FIXED - OGR can't handle Null values in a Date field
Mateusz Loskot
mateusz at loskot.net
Fri Jun 30 05:15:12 EDT 2006
Aaron Koning wrote:
> Is there anyway of getting OGR to output Null values into a Date
> field when there is a Null value present in the input Date field?
Last days, I fixed this issue but due to my Internet connection was
broken, I could not commit it.
So, now I can and I've committed my changes to CVS.
Changes:
- Fixed Shape driver - NULL/0 date value was converted to string without
zero fill for year, e.g. 0/00/00 instead of 0000/00/00.
- Fixed NULL handling in PG driver - now, if date field stores year of
0000, the value is considered as NULL, because there is no ZERO year
(this follows PostgreSQL/MySQL dates handling behaviour, interesting
reference:
http://groups.google.pl/group/mailing.database.pgsql-sql/browse_frm/thread/1685953a3ebf48c1
So, I was able to import Aaron's shapefile to PostgreSQL 8.1.4.
Here are my commands:
ogr2ogr -f PostgreSQL PG:dbname=gdal_nulldate bugs/null_date/dates.shp
NOTE: I renamed Aaron's shapefile to dates.shp
Here is what I got in my gdal_nulldate database:
gdal_nulldate=# \dt
List of relations
Schema | Name | Type | Owner
public | dates | table | mloskot
(1 row)
gdal_nulldate=# \d dates
Table "public.dates"
Column | Type | Modifiers
ogc_fid | integer | not null default
nextval('dates_ogc_fid_seq'::regclass)
wkb_geometry | bytea |
dstrbedate | date |
dstrbsdate | date |
licenceid | character(50) |
permitid | character(50) |
blknmbr | character(50) |
Indexes:
"dates_pk" PRIMARY KEY, btree (ogc_fid)
gdal_nulldate=# select dstrbedate, dstrbsdate from dates;
dstrbedate | dstrbsdate
2001-02-07 | 2001-02-07
2001-02-08 | 2001-02-08
2002-02-01 | 2002-02-01
2002-01-05 | 2002-01-05
1999-01-06 | 1999-01-06
1997-12-24 | 1997-12-24
1999-03-03 | 1999-03-03
2001-11-01 | 2001-11-01
1998-12-21 | 1998-12-21
1998-09-10 | 1998-09-10
1998-02-04 | 1998-02-04
2001-01-08 | 2001-01-08
1996-12-23 | 1996-12-23
1992-11-13 | 1992-11-13
1996-01-05 | 1996-01-05
1990-01-01 | 1990-01-01
(18 rows)
gdal_nulldate=#
NOTE: As you can see, two records store null dates, just as in the input
shapefile.
So, I assume this issue is fixed, but there are small things I'd like to
explain/learn (regarding OGR Shape driver and dates).
Please, see my comment marked with 'XXX - mloskot' in the
ogr/ogrsf_frmts/shape/shape2ogr.cpp file.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
