[Gdal-dev] Defining Australian Map Grid in GDAL
Delfos, Jacob
jacob.delfos at maunsell.com
Wed Mar 1 18:48:56 EST 2006
Andrew,
Theoretically, if you replace the incorrect lines in your EPSG
projection file (\proj\nad\epsg), then I believe you could do this:
gdalwarp -s_srs epsg:20255 -t_srs epsg:4326 -co "TFW=YES" image_in.tif
image_out.tif
As far as I can tell, that ought to work (and override the source
projection). There's a good chance your image does not in fact have a
datum defined, and it just defaults to WGS84.
Alternatively, you could use the parameters:
gdalwarp -s_srs "+proj=utm +zone=55 +south +a=6378160
+rf=298.250000000055
+towgs84=-129.193,-41.212,130.73,-0.246,-0.374,-0.329,-2.955 +units=m"
-t_srs "+proj=longlat +ellps=WGS84 +datum=WGS84" -co "TFW=YES"
image_in.tif image_out.tif
I'm no export on gdalwarp, so this may not work :)
Regards,
Jacob
> -----Original Message-----
> From: Andrew Williams [mailto:awilliams at rapidmap.com.au]
> Sent: 1 March 2006 14:22
> To: Delfos, Jacob
> Cc: gdal-dev at lists.maptools.org
> Subject: RE: [Gdal-dev] Defining Australian Map Grid in GDAL
> OK I've narrowed it down. Jacob is correct, there is a
> problem handling AGD datums. With the TFW file in the same
> directory as the source image I've attenpted to translate the
> image using the following command line
> +rf=298.250000000055" -t_srs "+proj=latlong +datum=WGS84" -co
> "TFW=YES" image_in.tif image_out.tif
> What is happening is that the system is being converted from
> grid to latlong but the source datum is still adopting WGS84.
> Therefore 200 odd metres out when computed to latlong.
> I have checked the varios csv's such as gcs, pcs, datum and
> ellipsoid and the correct parameter appear to be in place.
> The TFW only defines the top left corner of the image and the
> pixel dimension. Why would GDAL assume WGS84 when I have
> defined override parameters?
> Do I need to take Jacob's file and insert it into one of
> these other csv's? Any other ideas?
> regards
> Andrew
> From: Delfos, Jacob [mailto:jacob.delfos at maunsell.com]
> Sent: Wed 3/1/2006 11:02 AM
> To: Andrew Williams
> Andrew,
> You have to be careful with AGD-based projections in
> Proj4, because the definitions that exist in Proj4 are not
> correct (problem with datums). I'm attaching a file with
> correct definitions for AGD-based projections. I have myself
> spent several days trying to figure out why my coordinates
> were up to 200m off, only to realise that Proj4 does not
> appear to use the AGD84 and AGD66 datum correctly.
> Just for the record:
> AMG66 = UTM + AGD66-datum
> AMG84 = UTM + AGD84-datum
> MGA94 = UTM + GDA94-datum (where GDA94 can be
> substituted with WGS84)
> Be careful with the acronyms. You wouldn't be the first
> to start construction in the wrong spot :)
> For your image, I guess just override the projection,
> and project from Latlong AGD84 (epsg:4203, bottom of file I
> sent) to Latlong WGS84.
> Regards,
> Jacob
> JACOB DELFOS
> GIS ANALYST
> Maunsell Australia Pty Ltd
> 629 Newcastle Street, Leederville, WA 6007
> PO Box 81, Leederville, WA 6902
> Western Australia
> ABN 20 093 846 925
> Tel + 61 8 9281 6185
> Fax + 61 8 9281 6297
> <<agd84_agd66_proj4.txt>>
> > From: gdal-dev-bounces at lists.maptools.org
> > [mailto:gdal-dev-bounces at lists.maptools.org
> <mailto:gdal-dev-bounces at lists.maptools.org> ] On Behalf Of
> > Andrew Williams
> > Sent: 28 February 2006 22:27
> > To: gdal-dev at lists.maptools.org
> > Subject: [Gdal-dev] Defining Australian Map Grid in GDAL
> > Hello folks.
> > I'm having trouble with a Geotiff.
> > The scan is a topographic map sheet. The cartography and grid
> > on the sheet is based on AMG (Australian Map Grid). It is a
> > UTM projection based on the Australian National Spheroid,
> > ellps=aust_SA I believe.
> > My problem is that the GeoTiff has been georefernced as UTM
> > ellps=GRS80 datum=WGS84 incorrectly.
> > My intent is to gdalwarp the image to latlong WGS84.
> > I have tried for the better part of a day to attempt to
> > override or otherwise correct the georeferncing.
> Without success.
> > I have been very successful with GDAL in the past, but this
> > has stopped me.
> > The problem is that I can't seem to fully define AMG "enough"
> > to allow GDALwarp to reproject the image. It seems to default
> > to the source as being UTM WGS84.
> > I attempted to gdal_translate the image using the corrected
> > definition and then gdalwarp image, but that also failed.
> > the definition I have been using is "+proj=tmerc
> > +ellps=aust_SA +lat_0=0 +lon_0=147 +x_0=500000 +y_0=10000000
> > +k=0.9996 +south"
> > regards
> > Andrew
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
> <http://lists.maptools.org/mailman/listinfo/gdal-dev>
