[Gdal-dev] ogrinfo metadata output
Markus Neteler
neteler at itc.it
Thu Mar 2 05:33:20 EST 2006
Frank,
I observed that the -summary flag is gone in 'ogrinfo'.
It would be VERY useful to display some metadata:
Currently:
ogrinfo pollo_pat.shp
INFO: Open of `pollo_pat.shp'
using driver `ESRI Shapefile' successful.
1: pollo_pat (Point)
Desired:
Extent: (1619353.660000, 5061907.140000) - (1697751.000000, 5113358.260000)
Layer SRS WKT:
PROJCS["Transverse Mercator",
GEOGCS["international",
DATUM["Monte_Mario",
SPHEROID["international",6378388,297],
TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",1500000],
PARAMETER["false_northing",0],
UNIT["meter",1]]
I know, that things are printed when adding the layer name,
but then I get hundreds of lines (most of these info I don't
want to know):
ogrinfo pollo_pat.shp pollo_pat | wc -l
291
Do you see a chance to modify the standard output?
thanks
Markus
