[Gdal-dev] Problem on creating a simple point shapefile with OGR
Zheng, Lin ERDC-TEC-VA
Lin.Zheng at erdc.usace.army.mil
Fri Mar 3 09:21:02 EST 2006
Hi All,
I am a newbie on OGR. I read the OGR API tutorial and tried to compile
the "writing to OGR" example with Microsoft Visual C++ 6.0, where a single
shapefile is created using OGR. The program compiled successfully, but when
after I ran it, it returned:
"ERROR 1: point_out.shp is not a directory.
Creation of output file failed."
I also read through the documentation on ESRI shapefile, and it
specifically said that it is possible to use one of the files (.shp, .shx or
.dbf) in a shapefile set as the dataset name. Did I forget to add something?
Can anyone please help me?
Thank you very much.
Lin Zheng
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060303/5b4c1390/attachment.html
