[Gdal-dev] gdal configure problem
David Burken
dburken at comcast.net
Mon Mar 6 10:36:40 EST 2006
Hi Frank,
Just fyi, these are two things that I have to do every time I get a
configure update:
First I'm on:
mercury$ cat /etc/redhat-release
Fedora Core release 4 (Stentz)
mercury$ g++ -v
gcc version 4.0.2
NOTE my libtiff and geotiff are from cvs and installed in my
"/usr/local/ossim" sandbox (--prefix=/usr/local/ossim):
./configure --without-libtool --with-kakadu=/work/drb/kakadu/v5_1-00315N
--with-geos=no --with-odbc=no --with-libtiff=/usr/local/ossim
--with-geotiff=/usr/local/ossim --prefix=/usr/local/ossim
Gives:
checking for XTIFFClientOpen in -lgeotiff... no
configure: error: We require at least GeoTIFF 1.2.1. Consider using the
one supplied with GDAL
My geotiff installed in /usr/local/ossim is from cvs...
Second:
After commenting out the check in configure.in and doing autoconf the
configure works...
Then:
make[2]: Entering directory `/mnthdb1/work/drb/gdal/frmts/gtiff'
g++ -Wall -fPIC -O2 -I../../port -I../../gcore -I../../alg -I../../ogr
-I../../ogr/ogrsf_frmts -DOGR_ENABLED -c -o ../o/geotiff.o geotiff.cpp
geotiff.cpp:136:21: error: xtiffio.h: No such file or directory
geotiff.cpp:137:21: error: geotiff.h: No such file or directory
In GDALmake.opt:
CPPFLAGS has /usr/local/ossim/include
However it is not used. I have to add to:
GDAL_INCLUDE...
Take care,
Dave
