[Gdal-dev] GDAL_TRANSLATE Problem
salah jubeh s_jubeh at yahoo.com
Thu Mar 9 15:47:40 EST 2006
Hello Guys
  I used GDAL_translate to translate from geotiff format to HDF format and again to geotiff format.
  imgae.tif---->image.hdf---->image2.tif
  I checked the  HDF file it contains all meta data like projection , transformation matrix, and another tags. also i checked the image2.tif the result was not good no geographical coordinate, system no transformation matrix.
  I was able to compile GDAL with two HDF library versions "HDF41r5 and 42r1-win" but the result was the same.
  also i did another test i convert the HDF to ASCII file
  image.hdf----->imag.asc
  the result was good i get the correct coordinate and cellsize
  what is the problem here is it from gtiff driver or from HDF driver and how can it be fixed
Yahoo! Mail
Bring photos to life! New PhotoMail  makes sharing a breeze.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060309/0eca7af9/attachment.html
