[Gdal-dev] GDAL_TRANSLATE Problem
salah jubeh
s_jubeh at yahoo.com
Fri Mar 10 04:15:29 EST 2006
Hello guys
I checked the images with gdalinfo it gives me this result below but i tried two programs to open this image which are arcgis9.1 and Erdas both of them gave me that there is no coordinates, and projection system. yesterday i posted the first message because i checked the coordinates by using Erdas .
still there is a problem here which is software compatapility.
Projection=PROJCS["IMAGINE GeoTIFF Support
Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: egtf.c $ $Revision: 1.10.1.6 $ $Date: 2003/10/17 16:36:51EDT $
Projection Name = Transverse Mercator
Uni",GEOGCS["IMAGINE GeoTIFF Support
Unable to match Ellipsoid (Datum) to a Ge",DATUM["unknown",SPHEROID["unnamed",63
78137,298.2572220960423]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433
]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER
["central_meridian",24],PARAMETER["scale_factor",0.9996],PARAMETER["false_eastin
g",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]
Corner Coordinates:
Upper Left ( 477701.231, 3928005.706)
Lower Left ( 477701.231, 3927667.467)
Upper Right ( 478094.457, 3928005.706)
Lower Right ( 478094.457, 3927667.467)
Center ( 477897.844, 3927836.587)
Band 1 Block=615x6 Type=UInt16, ColorInterp=Gray
Hello Guys
I used GDAL_translate to translate from geotiff format to HDF format and again to geotiff format.
imgae.tif---->image.hdf---->image2.tif
I checked the HDF file it contains all meta data like projection , transformation matrix, and another tags. also i checked the image2.tif the result was not good no geographical coordinate, system no transformation matrix.
I was able to compile GDAL with two HDF library versions "HDF41r5 and 42r1-win" but the result was the same.
also i did another test i convert the HDF to ASCII file
image.hdf----->imag.asc
the result was good i get the correct coordinate and cellsize
what is the problem here is it from gtiff driver or from HDF dri! ver and how can it be fixed
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze. _______________________________________________
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
Yahoo! Mail
Use Photomail to share photos without annoying attachments.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060310/36fdfc32/attachment.html
