[Gdal-dev] Animation?
Norman Barker
nbarker at rsinc.com
Mon Mar 20 15:46:38 EST 2006
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org on behalf of Andy Bunn
Sent: Mon 20/03/2006 20:05
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Animation?
List: Any way to animate a flipbook of GeoTifs to an AVI on windows?
Thanks in advance.
-Andy
Given a directory with:
abunn at AndysD600 /cygdrive/y/PRISM/daily_adj/tmax_clipped_proj
$ ls | head
tmax_20040101.tif
tmax_20040102.tif
tmax_20040103.tif
tmax_20040104.tif
tmax_20040105.tif
tmax_20040106.tif
tmax_20040107.tif
tmax_20040108.tif
tmax_20040109.tif
tmax_20040110.tif
where each of 365 tiffs is nice and small at 133kb:
<snip>
we have just done this using MapServer WCS / GDAL on the server side, and IDL on the client side (though you could use Java / Python) any temporal OGC client.
The fact that you have got 16 bit data precludes using normal AVI software, also you will want to do frame interpolation for a smooth effect.
We used the temporal dimension of OGC WCS (implemented in MapServer) to serve the tifs, and then created an OGC temporal WCS client, I believe there are quite a few around in addition to ours.
Full details of serving temporal data is here anyway
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
and a list of OGC WCS clients that were developed for GALEON (some commercial some not, most supporting temporal animation) is here
http://galeon-wcs.jot.com/WikiHome
Hope this helps,
Norman
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060320/2013ff4f/attachment.html
