[Gdal-dev] Any tips for VB .NET?
Tamas Szekeres szekerest at gmail.com
Tue Mar 21 04:26:58 EST 2006
You could use the SWIG C# binding
or Morten's C# wrapper classes
http://www.iter.dk/blog.aspx?id=35
It must be noted that SWIG C# binding is currently uncomplete and not
thoroughly tested.
Tamas
2006/3/21, Holywhippet <amills at frogtech.com.au>:
>  I'd like to try and use GDAL from withing VB .NET if I can. In theory I can
> use "Declare Function" to link to the GDAL dll. However, I tried calling
> GDALOpen and assigning the output to a generic Object. I get an error saying
> the function value can't be returned as a variant. I'm not sure if this path
> is possible in general. Has anyone gotten GDAL to run using VB .NET?
> View this message in context: http://www.nabble.com/Any-tips-for-VB-.NET--t1315468.html#a3506881
> Sent from the GDAL - Dev forum at Nabble.com.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
