[Gdal-dev] Problem with gdalnumeric.SaveArray
Gillian Walter gillian.walter at vexcel.com
Mon Mar 20 19:32:52 EST 2006
I have been running into a problem with gdalnumeric.SaveArray in the
latest version of GDAL (using Fedora core 3 Linux, building GDAL from
current CVS with Python 2.3.5 and Numeric 23.0) and I'm wondering if
there's some sort of referencing issue.  If I enter the following
commands in the Python shell, I get a core dump:
import Numeric
import gdalnumeric
arr=Numeric.array([[5.3,1,2],[6,7,8]]).astype(Numeric.Float32)
arr # print array
gdalnumeric.SaveArray(arr,'/home/gwalter/junk.tif')
arr # try to print array again- Segfaults instead of printing
But, if I separate the SaveArray out into its component commands:
import Numeric
import gdalnumeric
import gdal
dr = gdal.GetDriverByName("GTiff")
arr # print array
ds=gdalnumeric.OpenArray(arr)
dr.CreateCopy('/home/gwalter/junk2.tif',ds)
the print works fine.  I am wondering about referencing problems because
  replacing:
with
dr.CreateCopy('/home/gwalter/junk2.tif',OpenArray(arr))
causes a segfault at the next array print.  Also, if you don't replace
the two calls with one, but delete ds, the next array print will segfault.
I did not have this problem in an older version of gdal; I'm not sure
when it crept in (I've been largely using a pre-PAM version of gdal).
Is anyone else able to reproduce this problem?
Gillian
