[Gdal-dev] raster query
Bryan Keith
bryan at geomega.com
Wed Mar 22 15:44:25 EST 2006
John,
I'm attaching a Python routine that queries a given band of a gdal
raster at a given x and y and returns the interpolated value. You'll
have to modify it a bit if you want the value of the raster without
interpolation.
I just updated it to work with rasters that have different cell size in
i and j. Hope it works and helps.
Bryan
Bryan Keith
GIS Specialist
Geomega, Inc.
Boulder, CO, USA
John Cartwright wrote:
> Hello All,
> does anyone know of a existing gdal tool for querying a raster? I'd
> like to get the raster value from a file for a given coordinate.
> Thanks!
> -- john
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
def PointValue(dataset, intBand, dblX, dblY):
#this routine returns the cellvalue on the band at (dblX, dblY) using bilinear interpolation
band = dataset.GetRasterBand(intBand)
dblNDV = band.GetNoDataValue()
lngXCount = band.XSize
lngYCount = band.YSize
geotransform = dataset.GetGeoTransform()
dblXMin = geotransform[0]
dblYMax = geotransform[3]
dblCellSizeX = geotransform[1]
dblCellSizeY = geotransform[5]
dblXLoc = (dblX - dblXMin) / dblCellSizeX
lngXLoc = int(dblXLoc)
dblYLoc = (dblYMax - dblY) / dblCellSizeY
lngYLoc = int(dblYLoc)
if ((dblXLoc < 0.5) or (dblXLoc > lngXCount - 0.5) or (dblYLoc < 0.5) or \
(dblYLoc > lngYCount - 0.5)):
return dblNDV
if ((dblXLoc - lngXLoc) < 0.5):
lngXLoc = lngXLoc - 1
if ((dblYLoc - lngYLoc) < 0.5):
lngYLoc = lngYLoc - 1
dblXPercent = ((dblXLoc - lngXLoc) + 0.5) - (int((dblXLoc - lngXLoc) + 0.5))
dblYPercent = ((dblYLoc - lngYLoc) + 0.5) - (int((dblYLoc - lngYLoc) + 0.5))
strRaster = band.ReadRaster(lngXLoc,lngYLoc,2,2,2,2,GDT_Float32)
dblValue = struct.unpack('f' * 4,strRaster)
if ((dblValue[0] == dblNDV) or (dblValue[1] == dblNDV) or (dblValue[2] == dblNDV) \
or (dblValue[3] == dblNDV)):
return dblNDV
dblX1 = dblValue[0] + ((dblValue[1] - dblValue[0]) * dblXPercent)
dblX2 = dblValue[2] + ((dblValue[3] - dblValue[2]) * dblXPercent)
dblValue = ((dblX2 - dblX1) * dblYPercent) + dblX1
#print dblX, dblY, dblValue
return dblValue
