[Gdal-dev] Error compiling gdal with MrSid support in ubuntu linux
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 29 09:37:56 EST 2006
Mikael Schröder wrote:
> Hello
> I have been trying to add support for MrSid (but also ecw) to the
> libgdal1c2(a) package in ubuntu breezy (I have also tried to compile
> directly from source).
> But I get the following error message:
> In file included from
> /usr/local/MrSid_GeoExpressSDK/include/support/lt_types.h:28,
> from mrsiddataset.cpp:117:
> /usr/local/MrSid_GeoExpressSDK/include/support/lt_platform.h:61:8:
> error: #error PLATFORM ERROR: Unsupported version of GCC
> make[3]: *** [../o/mrsiddataset.o] Error 1
> make[3]: Leaving directory
> `/home/micke/source/gdal_dpkg_t4/gdal-1.2.6/frmts/mrsid'
> make[2]: *** [mrsid-install-obj] Error 2
> make[2]: Leaving directory
> `/home/micke/source/gdal_dpkg_t4/gdal-1.2.6/frmts'
> make[1]: *** [frmts-target] Error 2
> make[1]: Leaving directory `/home/micke/source/gdal_dpkg_t4/gdal-1.2.6'
> make: *** [build-stamp] Error 2
> I have installed gcc 3.2.3 from Warty and downloaded the corresponding
> dsdk from Lizardtech's developer-site.
> Before i run dpkg I execute (as root):
> $ export PATH=/usr/bin/gcc-3.2:$PATH CC=/usr/bin/gcc-3.2
> $ PATH=/usr/bin/gcc-3.2:$PATH CC=/usr/bin/gcc-3.2 dpkg-buildpackage -us
> -uc -rfakeroot
> I have also linked gcc to gcc-3.2 in /usr/bin
> What am i doing wrong?
Mikael,
I don't know what dpkg does, but I would guess it is somehow not honouring
your environment. lt_platforms.h checks for gcc 2 and 3, so I would assume
things are still picking up gcc 4 for some reason.
You might trying setting CXX instead of (or in addition to) CC since this
is a c++ project.
I trust any package you build would only be for internal use, right? There
are non-trivial requirements to redistribute Lizardtech libraries (even if
you are putting it in non-free).
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
