[Gdal-dev] Problem creating MapInfo tab files using C# (via the
C API)
Richard Matsunaga
richard at waypointinfo.com
Wed Mar 29 10:52:06 EST 2006
Daniel,
I was finally able to try this out. It did indeed fix my problem. My MapInfo
files are now valid. Any way we can get this fix into the main release?
On a side note: the command line build doesn't work in VS.NET 2005. I had to
install 2003 to get the build working.
Cheers,
Richard
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at mapgears.com]
Sent: March 22, 2006 1:01 PM
To: gdal-dev at lists.maptools.org
Cc: Richard Matsunaga
Subject: Re: [Gdal-dev] Problem creating MapInfo tab files using C# (via the
C API)
Frank Warmerdam wrote:
> This might be worth taking up on the mitab list - this issue sounds
> vaguely familiar. I wonder if it might already have been fixed. Are
> you using GDAL CVS?
Frank,
Are you thinking of the problem with the #ifdef MITAB_AFFINE_PARAMS in MITAB
that causes unreadable files?
http://bugzilla.maptools.org/show_bug.cgi?id=1319
Richard: perhaps you could try recompiling GDAL after adding
-DMITAB_AFFINE_PARAMS to the CPPFLAGS variable in GDALmake.opt and let us
know if that solves the issue.
Daniel
Daniel Morissette
http://www.mapgears.com/
