[Gdal-dev] Error compiling gdal with MrSid support in ubuntu linux
Mikael Schröder
miscx at spray.se
Thu Mar 30 17:42:49 EST 2006
Ok, Thank you once more Frank!
/Best Regards, Mikael
tor 2006-03-30 klockan 17:09 -0500 skrev Frank Warmerdam:
> Mikael Schröder wrote:
> > Perfekt!
> > Thank you!!! It finally worked!
> > I will give the ecw-problem a try another day/night... (now that I got
> > MrSid working)
> > With "other C++ packages" you refer only to packages that depend upon
> > libgeos/libgdal right. like Qgis, mapserver etc.
> > What about PostGIS ??
> Mikael,
> I meant any other library for which GDAL, mapserver, etc use a C++
> interface. In your context the obvious candidates are mrsid, ecw, geos,
> gdal/ogr, mapserver and gqis. But there might be other packages that could
> be an issue.
> Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060331/66236d7e/attachment.html
