[Gdal-dev] Re: ruby bindings not compiling from CVS
Ken-ichi kueda at nature.berkeley.edu
Tue May 2 13:29:59 EDT 2006
No, no errors during the compilation, and no mention of 'ruby'
whatsoever during the same.  I take it you are unable to reproduce this
problem?
Ken-ichi Ueda
Kelly Research and Outreach Lab (http://kellylab.berkeley.edu)
University of California, Berkeley
Environmental Science, Policy, and Management
Berkeley, CA 94720
tel: 510.642.8322
fax: 510.642.1477
e-mail: kueda at nature.berkeley.edu
Charlie Savage wrote:
> Any error messages in the compiling stage?
> Charlie
> Ken-ichi wrote:
>> Hi Charlie,
>> Nope, the extension never gets built.  The only things in swig/ruby
>> are the sources and makefiles.
>> Ken-ichi Ueda
>> Berkeley, CA 94720
>> tel: 510.642.8322
>> fax: 510.642.1477
>>> Hi Ken-ichi,
>>> Is the extension successfully built?  IE., is there a gdal.so file
>>> in the swig/ruby directory?
>>> Charlie
>>>     Ken-ichi wrote:
>>>> Hi all,
>>>> When I try to compile the latest CVS (4.30.06) version of GDAL
>>>> --with-ruby, configuring and compiling go off without a hitch, but
>>>> when I try to make install, I get this error:
>>>> (cd swig; make install)
>>>> for dir in ruby ; do (cd $dir; make install ); done
>>>> make -f RubyMakefile.mk install
>>>> /bin/sh /usr/local/src/gdal-cvs-2006.04.30/libtool --mode=install
>>>> /usr/local/src/gdal-cvs-2006.04.30/install-sh -c gdal.so ogr.so
>>>> gdalconst.so osr.so
>>>> /usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal
>>>> /usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal/gdal.so
>>>> install:  gdal.so does not exist
>>>> make[3]: *** [install] Error 1
>>>> make[2]: *** [install] Error 2
>>>> make[1]: *** [install] Error 2
>>>> make: *** [install-actions] Error 2
>>>> It doesn't look like gdal.so is getting made at all.  I'm getting
>>>> basically the same error on Mac OS 10.4 and Gentoo Linux.  I do not
>>>> get this error on Gentoo with the 1.3.1 source (haven't tried that
>>>> one on my Mac yet).
>>>> Any thoughts?
