[Gdal-dev] Recommendations for vertical data in GDAL
Frank Warmerdam
warmerdam at pobox.com
Wed May 3 08:56:37 EDT 2006
Ray Gardener wrote:
> Antoine Hue wrote:
> > Without being an expert in this field, I have run into some of these
> issues while working on 3D terrain modeling from DEM. I fully support an
> initiative to make it more explicit that a layer is a DEM, what is the
> unit and pixel interpretation.
> > An extension to this is support for geocentric SRS and warp to/from
> geocentric SRS.
> I think that could be satisifed by
> a) having ORGSpatialRef parse GEOCCS nodes (if it doesn't already),
Ray,
Well, I think they will parse ok now because the parser doesn't
really look at what kinds of nodes it is parsing.
> b) adding an IsGeocentric() method,
agreed.
> c) adding a SetGeocentricCS() method,
agreed.
> b) doing any necessary mods to OGRCoordTransform to use such data when
> one or both of its spatialrefs are geocentric, and
PROJ.4 already supports geocentric coordinate systems. So I think we
would just have to update the to/from PROJ.4 format translation code
to support geocentric.
> c) formalizing the list of avail. geocentric datums.
Hmm, I'm not clear on what a geocentric datum is.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
