[GDAL-DEV] Query..
abhay menon
abhay.menon at gmail.com
Thu May 4 14:13:01 EDT 2006
Hello Lists,
I have few queries ...
1) can I use two different dataset (MapInfo File and/or ESRI Shapefile) and
preform a spatial operation and create a thrid output using the gdal/ogr
libraries.
2) If so can I prefrom a raster overlay analysis that could be conducted
with a raster and a vector dataset, which is used to updates the vector
dataset attributes with the certian values.
PS. Is there any sample programmes to developing code using gdal/ogr
libraries which I could lay my hands on.. other than source code of gdal.
Thanks & Regrads
Abhay Menon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060504/b252168c/attachment.html
