[Gdal-dev] Potential thrashing on band 1?
Ben Discoe
ben at vterrain.org
Fri May 5 01:45:46 EDT 2006
Thanks Frank. In case anyone else sees the thrash message, i made it go
away by increasing the cache with GDALSetCacheMax(). In this case, default
cache size was 10MB but my row of tiles was 12MB.
Curiously, gdalinfo reports a block of size 4093x21.
-Ben
> -----Original Message-----
> From: Frank Warmerdam
> Sent: Thursday, May 04, 2006 5:05 PM
> Stripped TIFF files often have several scanlines per strip
> (block). A gdalinfo report will tell you the effective block
> size for the file.
> > Then there is the mystery of why it complains about "band
> > 1", when i am reading all three bands identically.
> The "potential thrashing" debug message is just a bit of a
> hint to developers that there may be efficiency issues with
> how they are accessing data. I only report it for band 1
> since I imagine the results will generally be similar for other bands.
