Le vendredi 05 mai 2006 à 12:57 -0400, Frank Warmerdam a écrit : > > Create a gdal.ColorTable object and then write it with SetRasterColorTable() > on the band. Makeu sure you do this right after the create, and before > writing the raster data or else it will be too late. Hi Frank, It's working fine. Many thanks for the help Didrik
