[Gdal-dev] gdalwarp parameters
Frank Warmerdam
warmerdam at pobox.com
Mon May 8 10:52:49 EDT 2006
Shoaib Burq wrote:
> Hi
> I want to reproject an image which is currently in NAD83 Z21 to a
> custom projection.
> I am having some trouble getting the proj4 parameters to a custom
> projection right.
> I have been given the ArcGRID's prj.adf file and it looks like this:
> Projection MERCATOR
> Datum WGS84
> Spheroid WGS84
> Units METERS
> Zunits NO
> Xshift 0.0
> Yshift 0.0
> Parameters
> -180 0 0.0 /* longitude of central meridian
> 45 0 0.0 /* latitude of true scale
> 0.0 /* false easting (meters)
> 0.0 /* false northing (meters)
> Could some one please suggest the correct proj4 directive to give to
> gdalwarp's -t_srs ?
> I have tried
> "+proj=merc +lat_0=45.0 +lon_0=-180 +x_0=0 +y_0=0 +datum=WGS84
> +ellps=WGS84 +units=m"
> but this is not giving me the correct extents.
Shoaib,
I believe you should be using:
+proj=merc +lat_ts=45 +lon_0=-180 +datum=WGS84
+lat_ts is "latitude of true scale"
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
