[Gdal-dev] OGRCreateCoordinateTransformation
Frank Warmerdam
warmerdam at pobox.com
Mon May 8 13:37:13 EDT 2006
Cho Hyun-Kee wrote:
> Hello!
> I use GDAL Library for coordinate transformation.
> But whenever I use OGRCreateCoordinateTransformation function, it
> returns NULL value.
> The code is like tihs.
> OGRSpatialReference OSRInputCoordinateInform;
> OGRSpatialReference OSROutputCoordinateInform;
> OSRInputCoordinateInform.SetTM(38, 127, 0.9996, 100000, 200000);
> OSRInputCoordinateInform.importFromEPSG(4162);
> OSROutputCoordinateInform.SetUTM(52, TRUE);
> OSROutputCoordinateInform.importFromEPSG(4166);
> OGRCoordinateTransformation *poCoordinateTransform;
> poCoordinateTransform =
> OGRCreateCoordinateTransformation(&OSRInputCoordinateInform,
> &OSROutputCoordinateInform); // return NULL
> How can I use it??
Cho Hyun-Kee,
Instantiating an OGRCoordinateTransformation object results in
an attempt to load PROJ.4 as a .so/.dll. If that doesn't
work, you will get NULL back. Is it possible that the PROJ
shared library isn't installed an accessable on your system?
I would have expected some sort of error message to be issued
to stderr.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
