[Gdal-dev] ogr find neighbours
Didrik Pinte
dpinte at itae.be
Wed May 10 09:29:37 EDT 2006
In the process of implementing a model, I need to get a list of
neighbours for a shapefile containing polygons.
The file contains 11 polygons having lots of points.
The very simple python code i've developped now is just to test if for
each polygon it touches or overlaps the other polygons from the file.
BUT :
with 11 polygons, I makes 122 (11 * 11) tests of geometry.Touches and
122 tests of geometry.Overlaps. This is done in 60 seconds and thus is
too slow.
By hand, I can do it in 15 seconds maximum taking into account the time
to open the file with GRASS ;-)
Does anyone here have a great idea on how to do this more quickly ?
I've pasted the code below.
Thanks for your help
Didrik
def get_neighbours(self,queryLayer):
Returns a list of references to adjacent cells
self.neighbours = []
cobj = self.geom
queryLayer.ResetReading()
queryFeat = queryLayer.GetNextFeature()
while queryFeat is not None:
geometry = queryFeat.GetGeometryRef()
found = buffer.Touches(geometry)
if found > 0:
self.neighbours.append(queryFeat.Clone())
else:
found = buffer.Overlaps(geometry)
if found > 0:
queryFeat.Destroy()
queryLayer = None
return self.neighbours
Name: not available
Desc: Ceci est une partie de message
=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060510/b97f9794/attachment.bin
