[Gdal-dev] gdal ngpython win32
Didrik Pinte dpinte at itae.be
Thu May 11 10:13:49 EDT 2006
Le jeudi 11 mai 2006 à 15:31 +0200, Didrik Pinte a écrit :
> Le jeudi 11 mai 2006 à 13:58 +0200, Didrik Pinte a écrit :
> > It fails because the linker cannot find gdal_i.lib.
> I've hardcoded the path to gdal_i.lib in the swig/python/setup.py file
> in order to try the swig interface.
> It then builds correctly but the gdalnumeric.cpp file is not compiled.
> How does the swig module have to be installed ? Without gdalnumeric, it
> cannot work. I suppose that the old version is not the right one. Is
> there something missing. I've tried it under linux, it seems to be the
> same.
> Any guidance is welcome ;-)
> Didrik
Howard, thanks for the information.
GDAL python swig is not supporting gdalnumeric at the moment.
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060511/7647d5cf/attachment.bin
